I recently removed the old cd player (which mysteriously quit working) from the dash and replaced it with a new Kenwood mp3 player and experienced some electrical issues that I am hoping someone can help me out with. First of all, I removed the old deck and cut the plug-in off and replaced it with the one for the kenwood that I purchased specifically for the KW deck. Following the wiring diagram, which was easy, I spliced in the new one without any issues and then plugged in the new deck. It worked without fail! I then replaced the two panels and re-tested everything only to find that a) the RW defrost button no longer worked, b) the dash lights no longer worked, and c) the passenger side tail light and front parking light no longer worked! Upon inspecting the fuses, I found that the light fuse had blown so I replaced it and it blew again! Apparently there was a short somewhere but where? I unplugged the deck, replaced the fuse and the lights on the dash and the outside lights worked. The switch to the RW defogger still does not work. When I push the button it lights up but will not click into place. What did I do? Again, I followed the instructions on the package to install the plug-in but apparently something is not right. Any ideas? Please help! Ron Mason
Jan 13, 2007 at 12:53 PM
