Electrical problem
2002 Other Hyundai Models 6 cyl Automatic 79000 miles
Hi...
The RPM keeps dropping to zero when driving when it should be higher as you accelerate.
The car cuts off-battery seems fine but not tested.
Driving on hwy rpm dropped to zero-radio went off.
was able to make it back home-when parked car-speedometer needle stayed at 60mph-next day car did crank on-drove around corner (TCS/ABS lights are on-airbag light comes on too) car seems to jerk a little...rpm went back down to zero made it back around the corner to house-car would not start again-but started up yesterday.
Does not appear to be the alternator or battery based on this-could it be bad gas or transmission problem?
Also though the car is automatic-can put it in a 5-speed which as you know is a matter of pushing the gear from 1..2..3..4...5 no clutch.
Thanks for your help-sorry low on funding as donation can't be too high-just put an alternator in my other vehicle...thnx!
Hi...
Oct 24, 2008 at 8:42 AM
