2002 Hyundai Santa Fe wheel noise
2002 HYUNDAI
KB20
  • 21 POSTS
Here are the simptoms:
-Rolling at idle speed or just above there is a rubbing noise that seems to be coming from the left rear tire. Once I noticed it I replaced all rotors and pads, front and rear. It needed it anyways. Noise stayed
-Noise seems to stop if I touch the brakes.
-Noise has gotten progressively loader
-I replaced all tires and had an alignment, noise stayed
-Rear CV joint seems to be intact and in good running order by appearance.(no cracked boots, not broken seals. Feels firm)
-Tested rear caliper by taking it off the rotor and pressing the brake, It seemed to compress normally.
-I am also hearing a lot of squilling from the rear brakes, they are still very new. I cant seem to get rid of it.
Was looking for suggestions...I was thinking maybe the caliper isn't applying enough pressure or maybe not holding pressure at all. I have no brake fluid leaks
Any suggestions?
Nov 21, 2006 at 8:56 PM
ZACHISHI
any fix for this i am having the same problem. Thanks Zach
Mar 1, 2008 at 7:44 AM
KB20
  • 21 POSTS
Yes..I did get this fixed. I took it into a dealership and explained the problem to them. Them fixed it and said that the brake pad I had used where lesser quality ones with high metal content in them. Apparently the hyundai ones are better. I assume you could always go with the Higher priced ones from the auto store but I priced them in my area and it would be actually cheaper to go with the Genuine Hyundai ones. Good luck.
Mar 1, 2008 at 11:17 AM
