I put on a new alternator now i can not find the tension pulley bolt to tighten my belt can anyone help me locate it. 2001 Hyundai XG300 3.0
May 14, 2007 at 6:51 PM
TURBOTUFF20G
MEMBER
its toward the bottom. if u look at the motor from the passenger side its up and to the right of the crank pully the 14mm bolt is kinda hidden at the bottom of the metal pulley,, loosen 14mm nut on center of pulley then tighten up 14mm bolt beneath tensioner pully to tighten belt,, then tighten 14mm nut back up on center of pulley
