[quote:735e71d00a="bluelightnin6"]The fuel pressure regulator is built in to the fuel pump. Have you already replace fuel pump and still having fuel problems? Or do you need the fuel pump replacement procedures?
Thanks for using 2CarPros.com![/quote:735e71d00a]
Thanks for your reply. Basically I took it to get serviced and they said it was leaking fuel and it needs a new fuel pressure regulator so I went to a wrecker and got one. I just want to know how to fit it or should I take it back and get a fuel pump instead.
Hopefully you'll be able to help.
Apr 28, 2009 at 1:20 AM
