1997 Hyundai Lantra can someone help please
1997 HYUNDAI LANTRA
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTTY05
my lantra starts no problem then a couple of days later i will go to start it and nothing all dash lights work and have power to everything else!!!! when i turn the key nothing fuel pump makes its noise and thats it then i would leave car and not try 2 start for at least 2 hours and it will start first go please help
May 27, 2010 at 9:48 PM
Next time it happens-don't wait for nothing-Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 27, 2010 at 10:53 PM
