I need to change a worn water pump and might as well change the timing belt as well since I've heard it has to be taken off to change the water pump. I need to know what is involved with the job and if I should replace anything else while I'm at it, ie. crank seal and what's involved in that as well and also what torque setting will I need to know.
May 11, 2009 at 10:18 PM
