I was suddenly unable to shift gears.
There appears to be a disconnect between shift lever and gearbox. I can get the car into gear by moving the mechanism at the transmission manually, the transmission end of the connecting cables (shift lever to transmission) are connected ok. Once in gear, by pushing the gearstick forward, it will move the car out of gear, but nothing after that. A diagram of how it all connects at the gearshift lever end would be a help before I try to pull it all apart. Any brief suggestions on checking out the mechanism would also be helpful.
Jul 25, 2010 at 12:49 AM
