1995 Hyundai Excel what happend to my car
1995 HYUNDAI EXCEL
176,000 MILES • 4 CYL • FWD • MANUAL
XIJIAHAO88
hi there.. i just wanna ask why my engine make a weird noise sound like tek tek tek tek... .and like it shown at the speedometers ( check engine ). iit will be great if u guys tell me what wrong to my car and how to fix it... thanks alot...
Sep 2, 2009 at 7:38 AM
KHLOW2008
  • 41,814 POSTS
Hi xijiahao88, Thank you for the donation. It is not easy to diagnose noise problems unless you can give a good description of the noise and it occurs under what circumstances. If the ticking noise comes and goes off intermittently, it is caused by the hydraulic lifters. The hydraulic llfters would have to be replaced. When the CHECK engine light is showing, an error has been detected in the engine management system, You need to retrieve the trouble code to proceed with diagnosis and rectification. Here are procedures for retrieving codes. Let me know the codes retrieved so I can assist in resolving problem. RETRIEVING CODES WITH MIL ( Malfunction Indicator Light = Check Engine Light) 1 . Ensure battery is fully charged before retrieving codes. ECM memory is erased when battery is disconnected. Turn ignition on. Ground data link connector terminal No. 10 ("L" wire) for at least 2.5 seconds.
https://www.2carpros.com/forum/automotive_pictures/192750_DLC95AccentFig01_1.jpg
2 . Malfunction Indicator Light (MIL) will flash first code stored or Code 4444 (no fault detected).
https://www.2carpros.com/forum/automotive_pictures/192750_DTCReadFig02_1.jpg
MIL will continue to flash same code until terminal No. 10 is grounded again. Follow grounding procedure in step 1). 3 . MIL will flash the next code stored each time terminal No. 10 is grounded until it displays Code 3333 (end of output). Retrieve trouble codes before conducting component or harness tests.
Sep 2, 2009 at 10:02 AM
XIJIAHAO88
about the noise that i said.. its from the engine (place that u put oil.. ) and it doesnt stop making noise.. the noise keep going everytime while the the car is running or stop... that clicking noise make me uncomfortable. and i scare something will gone wrong to my engine.... btw i cant really understand about what u said for the "service engine" problem... thx alot to reply anyway...
Sep 2, 2009 at 12:24 PM
KHLOW2008
  • 41,814 POSTS
The noise location is the valve trains and that means my guess was correct, caused by valve lifters. It is quite comon for the valve lifters to produce the noise for such engines. An oil change might reduce the noise level but since noise is present all the time and not reducing, at least one of the lifter needs to be replaced.
The Check Engine Light, please refer to the following link for an explanation. Previous post is for retrieving the code without any scanner.
https://www.2carpros.com/dia/how_to_scan_trouble_codes.htm
Sep 2, 2009 at 1:45 PM
XIJIAHAO88
hi there... thx for last time... now i just wanna ask u guys about inlet air temp (IAT) sensor. do u guys know where is it about in my car? can u send a picture to me so i can know which one it is.. thanks alot anyway...
Sep 16, 2009 at 12:40 AM
KHLOW2008
  • 41,814 POSTS
Sorry I do not have any picture to show you. The IAt is plugged into the air cleaner at left side of engine compartment.
It is a 2 pin sensor which looks like a matchstick at the sensor end.
Sep 16, 2009 at 10:55 AM
