Hello .. thanks for the donation .. much appreciated
SHIFT LOCK SYSTEM
The shift lock system prevents gearshift lever from being moved from Park unless brake pedal is depressed, ignition is on and release button on side of gearshift lever is depressed. The shift lock system consists of shift and key lock control module, shift lock solenoid, park position switch and brakelight switch. See COMPONENT LOCATIONS . The shift and key lock control module controls operation of shift lock solenoid for gearshift lever operation. In case of a malfunction, gearshift lever can be released by depressing release button.
KEY LOCK SYSTEM
The key lock system prevents ignition key from being turned to LOCK position unless gearshift lever is in Park. Key lock system consists of shift and key lock control module, key lock solenoid and key lock switch. See COMPONENT LOCATIONS . The shift and key lock control module controls operation of key lock solenoid.
SHIFT LOCK SYSTEM
To check system operation, turn ignition on. Depress release button on side of gearshift lever.
With brake pedal released, gearshift lever should not move from Park. Depress brake pedal. With release button depressed, gearshift lever should now move from Park.
If shift lock system operation is not as specified, check brakelight switch and shift lock solenoid. See BRAKELIGHT SWITCH and SHIFT LOCK SOLENOID under COMPONENT TESTS. If necessary, check wiring and ground connections.
BRAKELIGHT SWITCH
Disconnect brakelight switch connector. Using DVOM, check for continuity between brakelight switch terminals with brake pedal depressed. Continuity should be present. Release brake pedal. Continuity should not be present. If continuity is as specified, brakelight switch is okay. If continuity is not as specified, go to next step.
Ensure brake pedal is properly adjusted so brakelight switch can obtain proper travel for switch operation. See BRAKELIGHT SWITCH under ADJUSTMENTS. If adjustment is okay, replace brakelight switch.
SHIFT LOCK SOLENOID
Disconnect shift lock solenoid connector. Using DVOM, measure resistance between shift lock solenoid terminals. Replace shift lock solenoid if resistance is not 12-16 ohms.
To check shift lock solenoid operation, connect battery voltage across shift lock solenoid terminals. When battery voltage is applied, a "clicking" sound should be heard to indicate solenoid operation. Replace shift lock solenoid if operation is not as specified.
Jul 9, 2020 at 12:15 PM
(Merged)
