Blower motor replacement instructions please?
2007 HYUNDAI ELANTRA
38,000 MILES • 4 CYL • FWD • AUTOMATIC
AKDOLORES
If my coolant lines were frozen, would that stop my heater from blowing air and thermostat not to work? Wouldn't my car have over heated from not having any fluid flow through the lines?
Dec 25, 2009 at 9:31 PM
First of all, the only way for your coolant to freeze is if you had only water in the system and not coolant. The other common name for coolant is antifreeze which is just what it sounds like. The coolant is alcohol so it doesn't actually freeze until a very low temperature.
So if you have heat issues then I suspect the coolant is just low so we should start with this. Here is a guide that will help with this:
https://www.2carpros.com/articles/car-heater-not-working
Here is another guide that could be the cause as well which is the blower motor:
https://youtu.be/1eau7hCuuJ8
Lastly you will see below the process from the manual on how to replace the blower motor if this proves to be the issue.
Feb 12, 2021 at 5:43 PM
WOOLEVER1965
please tell me where I can find blower motor resistor do you have a pic showing me
Feb 15, 2021 at 9:44 AM (Merged)
ZACKMAN
  • 4,202 POSTS
Inside blower motor assembly. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/55316_03elantrablower_1.jpg
ADRIAN3A
I believe I need to replace my blower motor or relay. The fan will blow sometimes, and then not at all other times. I heard unusual noises before the problem occurred. I can hear a click when I try to turn on my fan.
Where is the blower motor located for my make/model? Is it necessary to remove the dash in order to service this part?
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2001_hydia_elantra_blower_motor_1.jpg
it's behind the glove box it only pays a half hour to replace it so it can't be that hard to change.Make sure you have power and ground to it when it isn't working before you change the motor.
ADRIAN3A
Thanks for the advice/picture. I recently took a look at the underside of the glove box. I could see the blower. I tapped on it, and it started blowing.
you said, "Make sure you have power and ground to it when it isn't working before you change the motor."
Is this to make sure its just not a power issue? or that a cable is loose? Or is it for safety reasons?
SATURNTECH9
  • 30,869 POSTS
It's to make sure that it's not a power or ground issue.Also to make that it's not a loose connection.I would make sure the key and switch is off before you try to replace it.
BDEBOARD
I have reason to think the blower motor resistor has gone bad in my daughter's 2001 Elantra. The fan stopped working for her the other day but I can get it to come on if fan speed control knob is held between setting 3 and 4, or by pushing on the knob slightly. Maybe the problem is the control assembly itself, who knows? First I would like to confirm/eliminate the resistor as the source of the problem but I'm having problems finding it in order to test it. Thanks in advance.
SATURNTECH9
  • 30,869 POSTS
Sure sounds like the switch if you have to hold it between two speed settings.If you had a bad resistor card i dont how doing that would make any less bad.Do you have a mutlimeter so we can do some testing?
Feb 15, 2021 at 9:45 AM (Merged)
BDEBOARD
I do have a Multimeter. And I agree about the switch as a possible cause. I was curious about the resistor because of several other posts I have read from various online sources. Initially I was able to get the knob to stay in place between positions 3 and 4 and she drove around for a day or so with AC and a fan. Then she said it wouldn't stay in that position and she was right. The odd thing now is that if I push on the knob slightly (it seems somewhat spring-loaded) I can usually get the fan to run. But something has failed so hopefully I can find it. Thanks, first time user and will be happy to donate.
SATURNTECH9
  • 30,869 POSTS
Why dont you unplug the switch and if the connector or the switch itself has melted?I have it happen many times the switch fails and starts melting the connector and switch itself.
BDEBOARD
I will check the switch more closely, thanks. Do I have to remove part/all of the dash or is there another way of getting to it to check?
SATURNTECH9
  • 30,869 POSTS
Here is how to remove the ac controls.
