2005 engine turns over but wont start
2005 HYUNDAI ELANTRA
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
BMCGIVER
had blow out ripped out wire loom wired wire loom back now car wont start blow out on left front side engine turns over but wont start
Aug 2, 2008 at 6:23 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
All the tests are here.
Aug 2, 2008 at 6:28 PM
BHINDLEY
  • 9 POSTS
BAD IGNITION COIL CONNECTION TO WIRING HARNESS
It seems that the connector gets old and brittle after time. Becomes an intermittent problem. It is probably common and why there are so many posts about this. It was a devil to figure out.
I had a similar issue on my 1998 Hyundai GL (stick shift). After replacing the battery, fuel pump and relay, fuel filter, checking all the sensors, checking out the ECU which gave no codes, and paying a lot of different mechanics who couldn't figure it out I decided to try replacing the ignition coil. After that is seemed to work, then went a little funky. I discovered that it was running on just 2 cylinders. When I wiggled the wires to the ignition coil it resolved the problem which then came back. Upon swapping back the original ignition coil to test I found that the connector from the wiring harness was very brittle and after fiddling with it I realized that this was a problem. Not able to find a replacement connector easily I drove it around on 2 cylinders with one of the leads hard wired. It then consistently ran - but on only 2 cylinders. I then hard wired the other 2 yesterday. That seems to have fixed the issue. It was as simple as that. Intermittently bad connection to the ignition coil.
If you need to replace that connector it is "Ignition Coil Wire Harness For 96-00 Elantra, 97-01 Tiburon 27367 23000" Beware that Hyundai uses the same part number for the condenser part - so verify that. I had to wrong part sent to me twice before I gave up and hardwired it. That part costs about $30 if you can find it. Thought I would share...
Jul 23, 2017 at 12:23 PM
MHECKELS
Engine Mechanical problem
2004 Hyundai Elantra 4 cyl Front Wheel Drive Automatic 85,000 miles
While running my car died, and now will not start. It is getting gas and intermittent spark. I've replaced the PCV valve, Camshaft sensor, Crankshaft sensor, and plug wires.
Jul 24, 2017 at 3:09 PM (Merged)
Check the fuel pressure with a fuel pressure gauge designed for your system to rule out the pressure regulator/fuel filter and fuel pump when it checks out-start by checking the ignition components item to item. Fuel and Ignition system checks out-
Do an engine compression check.
