2004 Hyundai Elantra O2 Sensor
2004 HYUNDAI ELANTRA
87,000 MILES • 4 CYL • FWD • AUTOMATIC
ABINDER
I need to replace my o2 sensor. Looking at the front sensor I can clearly see there are 5 wires coming out of it. However, when I search various auto parts websites, most are selling o2 sensors with 4 wires and yet they claim that these are the correct items for my vehicle. Could these 4 wire sensors work and what is the difference? I have found some that sell 5 wire sensors but they are considerably more expensive. Is the difference worth it? I live and drive in AZ if that makes a difference.. Thank you
Feb 1, 2010 at 7:32 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Your car is probably the SULEV type they use a leniar O2 where others use heated 4 wire. You should check with dealer Federal Law states Mnaufacture must repair any polution devise for 10 yrs. 100K miles.
Hope this helps
Thanks for donate
Feb 2, 2010 at 10:14 AM
ABINDER
Thanks, but actually the engine is not the SULEV type but a 2.0 L DOHC 16-Valve CVVT engine. In this case, would a 4 wire o2 sensor work?
I did speak to the dealer, but they said it was not covered.
Feb 3, 2010 at 7:57 PM
DOCFIXIT
  • 18,828 POSTS
On that engine my info shows both front and rear O2 are four wire. Should be a black-Green-White_Pink wire
What colors are yours?
Feb 4, 2010 at 11:38 AM
ABINDER
The colors are White, Black, yellow, Gray, and Blue. I attached a picture if that helps. Thanks
https://www.2carpros.com/forum/automotive_pictures/474148_P1010245_1.jpg
Feb 4, 2010 at 5:40 PM
DOCFIXIT
  • 18,828 POSTS
Follow harness to connector what is wire color after connector?
Feb 5, 2010 at 2:17 PM
04ELEANTRA
Many people are fooled by the 10/100 myth. Here's the real info:
The Performance Warranty covers repairs which are required during
the first 2 years or 24,000 miles of vehicle use because the vehicle
failed an emission test. Specified major emission control components
are covered for the first 8 years or 80,000 miles.
Jul 23, 2011 at 11:11 PM
2005ELANTRA
Hello, this is old but I am in the same position except I already took out my old sensor which I will likely regret. The colors on the other side are two whites, light green, pink, brown, and yellow.
Thanks in advance
Nov 17, 2015 at 8:33 AM
