Front crank seal seeming very quickly came out of engine, noticed smoke in rear view mirror, pulled car over right away, oil light came on immediatley shut off to check oil and found hugh puddle of engine oil under right front of car, and no oil left in crank case. Took front of engine all apart found front crank seal pushed out. Installed new seal & timing belt, put in 2 litres of oil just to start engine before completely reassembling, and ran for about 1 minute, then turned off finish assembly, fill crank case with oil start engine again ran for another 3-4 minutes and suddenly a large puddle oil again, took all aprt again to find new seal pushed out of housing just as OEM seal was.?? what next ??
Jan 22, 2009 at 10:09 PM
