When I start my car on cold days (30 degrees) there's a loud squealing noise coming from the engine. It seems to get worse each day and sounds pretty bad and annoying. I had the power steering pump and the belt replaced several weeks ago. This solved the problem for a few days and then the squeal was back. Someone mentioned that it may be a CV joint? It worries me that the mechanic didn't fix the problem. He checked the car over and told us everything else looks fine. Timing belt, etc. Any ideas what could be causing the squealing noise?
Jan 24, 2010 at 9:46 AM
