2002 Hyundai Elantra why does my car hesitate?
2002 HYUNDAI ELANTRA
13,300 MILES • 4 CYL • 2WD • AUTOMATIC
JBOYES
My car is acting very strange. The engine wants to quit on me. It keeps stalling. When I am driving, the engive willl cut out for a few seconds and if I keep the gas on, it will like restart... It is hard to explain but it is almost like it shorts out. I have had cars not idle for me but this is different. It just dies
even when I am applying the gas to it. doesn't matter how fast or slow I am going.
We recently removed the catalytic converter because it was plugged and just put in a straight pipe. Could the two be related somehow?
Thanks for any help you might be able to provide. I know it is kind of vague but not sure how to explain any better.
Apr 14, 2010 at 2:19 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 14, 2010 at 4:42 PM
