how to change windshield washer pump?
2002 HYUNDAI ELANTRA
JACKNWATER
Engine Mechanical problem
2002 Hyundai Elantra 4 cyl
First off where is it located? I've never worked on a hyundai always fords only. Second is it hard to change? Looks fairly simple (looking at the part), but i guess the big question is where is it located? Thanks!
Jul 10, 2008 at 7:30 PM
KHLOW2008
  • 41,814 POSTS
Hi jacknwater,
If you can't find it in the engine compartment, then should be behind the front bumper inside the fenders.
(Here is a guide Below)
Cheers
Jul 12, 2008 at 8:27 AM
JACKNWATER
ok so it's not going to be in the washer container itself?
Jul 12, 2008 at 1:56 PM
KHLOW2008
  • 41,814 POSTS
Hi jacknwater,
Yes, it is attached to the bottom of the tank, pull out and plug in.
Jul 12, 2008 at 11:06 PM
HYUNDUN
For those with this in winter, your fluid and pump may be frozen partially or completely, I had just grabbed washer fluid off a store shelf, and turns out it was good only to +32 degrees, lol- poked down into the washer fluid tank with coat hanger to check and found ice, used hair dryer to warm pump and bottom of tank under fender below passenger headlight, then sprayed windshield de-icer into reservoir- might be okay to just use up or pump out or disconnect hose at pump output and add new fluid.
Jan 1, 2018 at 10:52 PM
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Jan 4, 2018 at 4:36 PM
HYUNDUN
Thank you, this website and thread helped me arrive at a solution for the problem- all the best-
Jan 4, 2018 at 9:25 PM
