2002 Hyundai Elantra Changing Clutch Disc
2002 HYUNDAI ELANTRA
165,000 MILES • 4 CYL • 2WD • MANUAL
KEVINSONHALER
Transmission will not seperate from block only half inch. Is there somthing that I am doing wrong. Tranny mounts removed.cables removed.Trans axles pulled. Please reply
Mar 8, 2008 at 6:35 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have to ensure ever thing is undone, if the transmission will retract evenly then it will be seized in the splines of the clutch disc or something is hanging up on the transmission externally, i would support the transmission and lever evenly from side to side to make sure the splines are free it should just slide straight out.
Mark (mhpautos)
Mar 10, 2008 at 5:12 AM
