2002 Hyundai Elantra cabin fan switch
2002 HYUNDAI ELANTRA
105,000 MILES • 4 CYL • 2WD • MANUAL
ROBK47
My AC/heater fan switch has stopped working in the low speed position. If I shift the switch slightly below or above the detent the fan will run. I suspect that it is a bad switch which looks to be easy to replace as I have had the panel that it is in out before. Is the switch available from anywhere other than the dealer. Does my diagnosis seem correct?
Thanks, Rob
Aug 2, 2009 at 11:56 PM
It does sound like a bad switch. You should be able to get the switch at a parts store or a salvage yard.
Aug 5, 2009 at 7:28 PM
