2002 Hyundai Elantra AIR BAG LIGHT ON
2002 HYUNDAI ELANTRA
98,000 MILES • 4 CYL • FWD • MANUAL
ROLOAVALOS
THE AIR BAG LIGHT IS ON THE DEALER WANTS 150.00 JUST TO CHECK IT ANY BODY KNOWS WHAT IT COULD BE .
Feb 17, 2009 at 12:04 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Go get a scan done as this will give you the fault code, often it is a problem with the clock spring which is part of the firing mechanism, if so this is a fix that you should not attempt, the air bag is in op till this fault is repaired.
mark (mhpautos)
Feb 17, 2009 at 1:10 AM
