Engine was vibrating at idle, gets worse when AC is on. I installed new spark plugs, wires and PCV. I did not find any vacuum leaks and the spark plugs were clean no oil residue from bad spark plug seals. The motor mounts are all good, no play and there is 20000 miles on the timing belt. Compression is good. No codes and mil is operating correctly. I am running out of options, should I try isolating each fuel injector ?? The car does not hesitate and pick-up is good.
Jun 1, 2010 at 9:03 PM
