Electrical problem
2001 Hyundai Elantra 4 cyl Two Wheel Drive Manual 190k miles
i drive an hour to work and this is quite an issue.
this car has started to do strange things. i can sit in the car and have the radio on and if i advance the ignition switch it can loose all power. it is as if there is no battery. once a battery tester is hooked up to it, everything comes back on.
it will also do this if i activate another device such as a window switch. but, not all the time.
i can go out in the morning when the car is cold, and once i turn the ignition to start, there it goes again. open and close the door, "juggle" the ignition switch and it comes back on. this does not always work. it has become like a "crap shoot" as to what will happen.
the car has been to the same tech shop twice and of course it behaved perfectly.
at wits end here!
at wits end here!
Jan 18, 2010 at 7:53 AM
