2000 Hyundai Elantra crank position sensor
2000 HYUNDAI ELANTRA
150,000 MILES • 4 CYL • FWD • MANUAL
JREED72
where is the crank position sensor at? and what do i have to do to replace it?
May 23, 2008 at 7:30 PM
BMRFIXIT
  • 19,053 POSTS
hope that clear thinks for you you can use an ohm meter to check it and if you are using a scanner u check for pending codes check for RPM reading while engine cranking
https://www.2carpros.com/forum/automotive_pictures/99387_hyunda_1.jpg
May 23, 2008 at 7:53 PM
