1999 Hyundai Elantra starter grinding on flywheel
1999 HYUNDAI ELANTRA
165,000 MILES • 4 CYL • FWD • AUTOMATIC
HOPSING420
  • 25 POSTS
we put an engine in this car and now the starter is grinding on the flywheel it did ok for about three months then the starter went out and the guy changed the starter hisself that one grinded on the flywheel and burred the teeth now every starter last about 3 days we have changed the thrust bearings the torque converter and the flex plate several times on the converter and flex plate but now the starters will not engage and have been breaking the top ear off of the starter housing
Apr 20, 2010 at 10:08 AM
KHLOW2008
  • 41,814 POSTS
Hi hopsing420,
For starters to grind and going out that often it could either be a mismatched starter motor and flywheel or the alignment of the starter.
Did problem occured immediately after replacement of the engine?
Apr 22, 2010 at 12:53 PM
HOPSING420
  • 25 POSTS
have recently found out that they had an early an late 99 production and to make this motor work I am supposed to use the flex plate from a 92-94 with a sppecial washe I ran into this once before when I was 18 they totalled the car before we got the problem fixed
Apr 26, 2010 at 12:13 PM
KHLOW2008
  • 41,814 POSTS
Thank you for the input and sorry to hear of the totalled vehicle.
Apr 27, 2010 at 10:09 AM
HOPSING420
  • 25 POSTS
they had full coverage and the vehicle had an "accident" over a cliff and into the lake
Apr 28, 2010 at 10:15 AM
KHLOW2008
  • 41,814 POSTS
At least the problem is solved.
Apr 28, 2010 at 1:11 PM
