1997 Hyundai Elantra transmission fluid tempature sensor A
1997 HYUNDAI ELANTRA
108,000 MILES • 4 CYL • FWD • AUTOMATIC
BLARSON
trying to find out how to do removal and instalation of Emissions code comes back po712 only thing im getting from every one is most likley a shorted trans temp sensor remove the pan .... that dosnt tell me anything....hope you can help me out...thank you.
Feb 23, 2009 at 5:27 PM
ZACKMAN
  • 4,202 POSTS
Just as if you are draining the transmission fluid to remove the trans filter.
https://www.2carpros.com/forum/automotive_pictures/55316_elantratransswitch_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_elantratransswitch_2.jpg
Instead of just removing the switch, you need to also check the wiring for cut, frayed or burned wires.
Feb 24, 2009 at 2:26 AM
