1995 Hyundai Elantra Rotor removal
1995 HYUNDAI ELANTRA
150,000 MILES • 4 CYL • 4WD • MANUAL
BDROSS
I cannot figure out how the rotor comes off the front of this car. I have done many disc brakes before and never could I not remove the rotor. The caliper assembly has been romoved as well as the lock nut and cotter pin and nothing! Please help.
Thanks, Brian
Jun 8, 2008 at 5:31 PM
KHLOW2008
  • 41,814 POSTS
Hi BDRoss,
The hub is pressed into the bearings. If the rotor is tightened with 4 bolts behind the hub, you need to pull the hub out with a puller.
Jun 9, 2008 at 9:11 AM
