2009 Hyundai Accent cruise control install
2009 HYUNDAI ACCENT
950 MILES • 4 CYL • FWD • MANUAL
PAUL HAYAUX
I just installed a 250-1799 cruise control unit with clutch switch into my car. This was an easy install with only a couple of electrical splices.1) power from new harness to power line in fuse box 2) power from on side of brake swich to new harnes 3) other side of brake switch through cluch switch to new harnes 4) Harness to VSS signal in diagnostic plug. Unit works great BUT!!!! If you hit the horn it doesn't blow but the CHECK FUEL CAP alarm lights up on the dash.
I've gone over all of my connections and don't see any exposed conductors thar could be shorting out.The only thing I can't get a good look at is were all the wires feed through the bulk head by the drivers feet.
May 1, 2009 at 2:28 PM
BMRFIXIT
  • 19,053 POSTS
You had no issues before the installation
I would suspect you taped into wrong wire
recheck your wiring and where you connected them
May 2, 2009 at 10:17 PM
PAUL HAYAUX
Sorry but I withdrew my donation yesterday at 2:47pm after I resolved my own problem. What I had done is short out 2 wires when I was running my wire hatness through the fire wall. What you proposed was the first thing I did when I realized I had a problem.
May 3, 2009 at 1:59 PM
BMRFIXIT
  • 19,053 POSTS
All good and very happy for you
its all worked out OK
happy driving
May 3, 2009 at 4:02 PM
