door cannot open from outside, lift-up lever doesn't work.
Feb 7, 2010 at 3:39 PM
2CARPRO JACK
CERTIFIED EXPERT
Sounds like the outside door handle may be broken.You will need to remove the inner door panel to gain visual access to the inside of the door so you can see if the outer handle is broken where the rod attaches. if so it will need to be replaced
