Rear lights will not go off, checked relay under hood ok, checked fuses under dash ok, I did look at the brake switch at the pedal, I pulled the white part off the actual switch and there is a pin sticking out of that and the realy part dosen't fit tight in the housing.Could that switch be bad? And if so is there anyway to check it before I buy a new one??
May 28, 2008 at 11:26 PM
