Transmission problem
2001 Hyundai Accent 4 cyl Two Wheel Drive Automatic
my check engine light came on and found code P0722 and P0133. no problem to change o2 sensor -probably should be changed . read lot of info about reprogramming and trying to decide.. if i just change the part... will the code still show up? Or should i get the reprogramming before replacing parts??
Also.. if i do not change parts.. thinking i only need reprogramming.... will this do any damage??
If i do change the parts.. will it clear the code??
my car is running fine.
will it effect my car inspection??
what advise/ info can you share??
Jul 24, 2008 at 9:11 AM
