2001 Hyundai Accent Can't fill gas tank
2001 HYUNDAI ACCENT
105,000 MILES • 4 CYL • FWD • MANUAL
MICHAEL1116
Every time I try to fill the tank, the pump shuts off after 2 seconds. It takes forever to fill. I know there is an air line that allows air to escape from the tank as you fill it.
I found a valve on this line which allows air to flow in only one direction (appears to be functional), which makes sense. It feels like the air flow is restricted somehow, which triggers the pump shut off. Is there a solution to this problem, that does not involve a $500 trip to the shop?
Oct 5, 2008 at 6:57 PM
2CARPRO JACK
  • 11,533 POSTS
They are blaming it on the pump at your gas station.They do give this procedure to find the restriction per TSB -99-30-002. 1- Disconnect the hose connected to the canister side of the liquid-vapor seperator (see pic) 2- Take car to know "good: or major brand gas station. A- if it accepts fuel, the restriction is between the liquid-vapor seperator and the air filter B- If it doesnt accept fuel,the restriction is between the liquid-vapor seperator and the fuel tank
https://www.2carpros.com/forum/automotive_pictures/1639_hyundai_1.jpg
Oct 7, 2008 at 8:00 AM
