2000 Accent GL- 7 DTCs - p1123, p1529, p0442, p0441, p0734, p0732, p0722. I understand that some of these codes are related. I replaced the purge control valve today and need to also replace a small vac hose on the manifold. My main concern is codes 1123, 0734, 0732 & 0722, and I read somewhere that 1529 could be a TCM problem and that there is a fuse somewhere for this particular item, which I cannot locate. Is it labeled differently? what causes incorrect gear ratios for codes 0734 and 0732? Where should I start for 1123? this car also idles rough and shifts poorly, especially from 1st gear and I've heard it could be a pulse generator. Where is this located? All help will be greatly appreciated! UPDATE- I have also seen some info reguarding code 0722 in the recall service bulletin, but I cant seem to access the actual bulletines. There are at least 4 recalls on the 0722 code for the pulse generator. Is there a way to see if it is bad or should I just replace it and cross my fingers? I would prefer to take a match to the car, but it belongs to my sister and is the only mode of transportation for her and her fiance, so I'm trying to do what I can for her for as cheap as possible. Again, thank you.
Apr 13, 2010 at 7:59 PM
