2000 Hyundai Accent P0441 Evaporative Emiss Control System
2000 HYUNDAI ACCENT
225,000 MILES • 4 CYL • FWD • AUTOMATIC
TOTALLYNASTY
I have received the error code of P0441. Car will not pass emissions.
It also gives me a problem when new gas is put in. I usually fill the tank each time and it won't start, I have to pump the gas pedal for it to start.
What are the possible issues and solutions?
Thanks
Teena
Jun 1, 2009 at 1:29 PM
DOCHAGERTY
  • 9,603 POSTS
The problem could be a stuck tank vent valve or a crack in one of the lines, the fault you report is low purge flow. I suggest speaking to your mechanic and have the evaporative system smoke tested to find the culprit.
Jun 1, 2009 at 1:42 PM
