2000 Hyundai Accent Engine will not Rev above 1200rpm then
2000 HYUNDAI ACCENT
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
WHTFYR2
  • 7 POSTS
My Hyundai was stored for a while before I bought it, I bought it knowing it needed plug wires/plugs because they were arcing due to wear. I attempted to drive it home and the Catalytic converter got red hot, so I stopped, replaced plugs and wires, it ran better but had no power. I replaced the Catalytic it was totally clogged, Now it still barely runs. It has no power. I used my diagnostic tool It gave me alot of codes. Misfires in all cylinders, Evaporative code, a hot tranny code and more. I just want to get it running. Why wont it rev up? Where should I start?
May 24, 2009 at 3:54 PM
ZACKMAN
  • 4,202 POSTS
Let's start by posting ALL the code numbers. We'll provide the proper diagnostic for each code. When you replaced the converter, did you make sure parts of it didn't clog the muffler? Does it seem to have normal exhaust back pressure?
Also, can you tell me all of the items the scanner came up with when you checked it?
May 25, 2009 at 12:43 AM
WHTFYR2
  • 7 POSTS
Ok I have read my users manual on the codes but here are the codes:
P0300, P1529, P0304, P0302, P1128, P0303, P0301, P0713, P0734, P0732, P0722, P0717.
Due to the misfire codes I have replaced the spark plug wires and plugs. Also my code reader will only read up to 12 codes at a time, so there could be more. I have replaced the fuel filter due to it not wanting to idle. Now it won't start at all, the filter is in right. When I turn the ignition on I do hear the fuel pump. Thanks for the help.
May 27, 2009 at 9:15 AM
WHTFYR2
  • 7 POSTS
Ok I asked a question and included a donation. I got an answer to include codes. I inculded the codes later and no answer, No help. So Thanks...now credit my paypal account back. I will call Paypal to credit my account if you dont.
May 27, 2009 at 7:03 PM
WHTFYR2
  • 7 POSTS
BEWARE!!! DON'T PATRONIZE 2CARPROS if you have a scoupe accent elantra tiburon or any other hyundai. Read my complaint above and look at the answer...There is none. I am very dissatisfied with there so called advice. It is a waste of money...They don't get back to you. I posted on a Sunday and its now Thursday with no follow up response. I waited for a response to order parts and fix my car. This site is a scam. BEWARE!!!
May 28, 2009 at 8:33 AM
JASONRAY
  • 213 POSTS
If you would like, I'll try to help you. I read your original complaint and all the follow up complaints and details. OK..the car sat up for a while, and now it has NO power. You've done SOME work to it so let's do this. Clear ALL the codes and drive it. See what codes 'reset' so we'll know what HAS been taken care of and what HAS NOT. Then we'll start from scratch. No power could be caused be lack of fuel PRESSURE or fuel VOLUME. But we need a place to start. Drive it til it resets the check engine light and pull the codes and tell me what they are. I'll help you.
Jun 2, 2009 at 1:41 PM
WHTFYR2
  • 7 POSTS
It will not start now. codes have been cleared.
Jun 2, 2009 at 6:49 PM
WHTFYR2
  • 7 POSTS
It will turnover and it has spark. I have changed two sensors, the Crank Position Sensor and the Throttle Position Switch...It still turns over but will not start.
Jun 2, 2009 at 6:50 PM
JASONRAY
  • 213 POSTS
Ok, considering you can't drive it at all now and there's no codes setting, we'll have to start from scratch. First, let's make sure the timing belt is still in tact and turning the camshaft. You can pull the upper timing cover back a little bit to see the cam pulley. You may have to take a couple of small bolts out if it won't pull back far enough. Have someone spin it over while you watch the cam pulley. Is it turning? If not, the timing belt broke or came off for some reason. I'll be doing some research in the meantime because a lot of Hyundai's engines are 'interferrence' engines, meaning that if the timing belt breaks, lots of damage will occur when the valves hit the pistons. Chech that and get back with me. If all is well, in that department, we'll check fuel supply to the injectors and the operation of the injectors. From your original posts, it may be fuel related since it was severely lacking power. Fuel pressure, as well as fuel volume, or the lack thereof, will cause a dramatic loss in power. We'll figure it out.
Jun 3, 2009 at 8:37 AM
WHTFYR2
  • 7 POSTS
Ok I pried open the timing belt cover and the timing belt is intact and spinning when turned over. I changed the Crank Position Sensor and the Throttle Position Switch/Sensor. Still will not start, but it does crank over and has spark to the plugs.
Jun 8, 2009 at 9:26 PM
JASONRAY
  • 213 POSTS
Ok... now...do you have access to a 'noid light'? If not, don't worry, just use a regular test light. Unplug one of the fuel injectors. turn the key ON. Connect the test light to 'ground' and probe the injector connector. One wire should light the test light. Does it? If so, connect the test light to BATT +(voltage) and probe the other wire. Have someone spin the motor while you're probing the other wire in the connector. Does the test light flash quickly? If not, the injectors are not 'pulsing'. If so, let me know and we'll go to the next step.
Jun 9, 2009 at 8:17 AM
