2000 Hyundai Accent disable warning lite
2000 HYUNDAI ACCENT
119,500 MILES • 4 CYL • 2WD • AUTOMATIC
HERCULES ROCKEFELLER
  • 4 POSTS
My hatch latch open light continues to stay on when latch is securly closed.I know eventually this will kill battery.Where do I start to disconnect/track down problem?
Apr 25, 2009 at 8:33 AM
DOCHAGERTY
  • 9,603 POSTS
Might I suggest inspecting the latch/switch assembly.
Apr 25, 2009 at 9:07 AM
  • 4 POSTS
[quote:d5f18fa50d="Dr. Hagerty"]Might I suggest inspecting the latch/switch assembly.[/quote:d5f18fa50d]
Took apart assembly everything looks OK.Wire looks a little frayed,could that be problem?(The wire I refer to is the one plugged into latch assem.)
Apr 25, 2009 at 10:04 AM
  • 4 POSTS
Now it seems the light goes out when brake is depressed.Any ideas?
[quote:0929a80915="Hercules Rockefeller"][quote:0929a80915="Dr. Hagerty"]Might I suggest inspecting the latch/switch assembly.[/quote:0929a80915]
Took apart assembly everything looks OK.Wire looks a little frayed,could that be problem?(The wire I refer to is the one plugged into latch assem.)[/quote:0929a80915]
Apr 25, 2009 at 12:15 PM
  • 4 POSTS
Somebody please help!
May 19, 2009 at 10:23 AM
DOCHAGERTY
  • 9,603 POSTS
Frayed wires, I am concerned
Aug 11, 2009 at 11:57 PM
