1999 Hyundai Accent rear drums
1999 HYUNDAI ACCENT
JAMWHIT57
Brakes problem
1999 Hyundai Accent 4 cyl Two Wheel Drive Manual
how do I remove the rear drums to renew shoes
Jun 3, 2008 at 12:20 PM
BMRFIXIT
  • 19,053 POSTS
Raise and support vehicle
remove rear wheel
remove rear drum
if difficult to remove drum
u can use 2 metric bolts into threaded holes in the brake drum
and tighten side to side
or you can remove grease cap on hub
remove self -locking nut or cotter pin and nut
remove outer wheel bearing
remove brake drum and hub assembly
Jun 4, 2008 at 6:19 AM
