[quote:0b27f398ac="suzonka"][quote:0b27f398ac="suzonka"][quote:0b27f398ac="BMRFIXIT"]Is it the canister that you need to replace or air filter
air filter under hood
canister is under left rear of the car[/quote:0b27f398ac]
NO NOT THE ENGINE AIR FILTER , THE CHARCOLE CANISTER IN THE FRONT UNDER THE HOOD ITS UNDER THE BATTERY BOX BUT I CAN NOT FIND THE LITTLE CANISTER AIR CLEANER FILTER[VERY SMALL][/quote:0b27f398ac]
or does the engine air filter have a line from the canister going into it and there really isnt a separate tiny air filter for the cantister[/quote:0b27f398ac]@@@@@@@@@@@@@@@@@@
when I LOOKED UP THE PARTS for the fuel system , it showed a purge valve leading to a air filter, it may be that a line goes to the engine air filter ,this is what Im trying to find out because I have a fuel filling problem at the pump and it says to check out everything back to the canister and purge valve plus an air filter,?? dont know much about this.
May 2, 2009 at 4:04 PM
