1995 Hyundai Accent replacing starter
1995 HYUNDAI ACCENT
NATBEN
Transmission problem
1995 Hyundai Accent Front Wheel Drive Manual 145000 miles
where is the starter located,diagram please,how to replace
Nov 5, 2010 at 5:25 AM
KHLOW2008
  • 41,814 POSTS
Hi natben, Starter is located at end of battery positive cable. In diagram, the starter bolts are attached to " C " on the transmission, under the manifold.
https://www.2carpros.com/forum/automotive_pictures/192750_Starter95AccentFig01_1.jpg
Sorry I could not find any other diagrams to show you. STARTER Removal & Installation Disconnect negative battery cable. Remove speedometer cable and shift cable. Disconnect starter motor connector and wire. Remove starter. To install, reverse removal procedure.
Nov 5, 2010 at 5:42 AM
