ON THE "SLAVE CYLINDER" YOU WILL SEE A BLEED PORT SIMILAR TO A BRAKE BLEEDER SCREW
THE SLAVE WILL BE LOCATED SOMEWHERE ON/ CLOSE TO THE BELL HOUSING
BLEEDING THIS WILL EVENTUALLY EXPEL ALL OF THE AIR IN THE SYSTEM
IF YOU ARE CONTINUALLY ADDING FLUID TO THE CLUTCH MASTER CYLINDER.......YOU HAVE AN EXTERNAL LEAK SOMEWHERE.........YOU MUST FIX IT OR REPLACE THE LEAKING COMPONENT BEFORE THE PROBLEM WILL STOP
IF YOU DO NOT HAVE AN EXTERNAL LEAK.....AND YOUR SYSTEM "BACKS OFF" WHILE THE PEDAL IS DEPRESSED.......THE INTERNAL SEALS IN EITHER THE CLUTCH MASTER CYLINDER OR THE SLAVE ARE ALLOWING FLUID TO SLIP PAST.........SOMETIMES THIS CONDITION IS REFEREED TO AS AN "INTERNAL LEAK", AS THERE IS NO FLUID LOSS...................WHICHEVER COMPONENT IS THE PROBLEM NEEDS TO EITHER BE "REBUILT" OR "REPLACED"........SINCE BOTH ITEMS MAY BE OLD AND POSSIBLY HAVE INTERNAL METAL DAMAGE, AND SOMETIMES A PAIN IN THE BUTT TO DETERMINE WHICH IS THE PROBLEM CHILD, MANY PEOPLE JUST REPLACE BOTH AS "PREVENTATIVE MAINTENANCE"
JUDGING FROM THE PRICE I FOUND IN THIS LINK FOR THE SLAVE, THIS MAY BE RELATIVELY INEXPENSIVE. THE SLAVE LOOKS TO BE AN EXTERNAL PART (AS WITH MOST OTHER '80s VEHICLES) SO, IT WILL PROBABLY BE AN EZ REPAIR....COMPARED TO "90s +" STUFF
THE LINK I GAVE YOU WAS JUST A "QUICK FIND", IT MAY NOT BE THE BEST DEAL.......I CAN SHARE MY TECHNIQUEs ON FINDING THE "BEST DEALS" ON FINDING AUTO PARTS ONLINE, AS WELL AS FOR ANYTHING ELSE....LEMME KNOW
YOUR TURN
THE MEDIC
Jun 3, 2013 at 7:08 PM
