The van listed above is a C3500. I need the diagram for the HVAC dash control vacuum valve for color/path vacuum lines. Color/numbers for each vacuum line coming from the control valve that is pictured. I believe port #8 on the valve is the source. And I believe port #6 is the MAX setting.
But I am having no luck once installed. If I jump the source to the blue vacuum line, my main flap opens, which would mean MAX, but when installed, nothing works. This is a brand new vacuum valve, and I believe someone has moved the vacuum lines around.
In other words, when the slide is moved to MAX on the dash, what path should the vacuum take? - Source vacuum to what color/number vacuum line?
Thank you.
Thank you.
May 28, 2020 at 4:23 PM
