HVAC recirculation door actuator clicking two months after replacement?
1999 SATURN SL2
96,000 MILES • 2WD • AUTOMATIC
BIG DUBBS
  • 4 POSTS
Does the vehicle listed above have a calibration process to perform after replacing the recirculation door actuator?
The controls are all manual, slides for both temperature and vent outputs. On/off buttons for AC and for inside/outside air.
Jul 10, 2025 at 8:46 AM
STEVE W.
  • 15,113 POSTS
No calibration required. Clicking is usually a damaged gear in the actuator. I can say that the quality of aftermarket actuators is abysmal. The OE part 89018370 is still out there.
Jul 10, 2025 at 10:42 AM
BIG DUBBS
  • 4 POSTS
Thanks, I will try to find one. I have the old original OEM part. Maybe I could swap the gears. Or maybe lube the crap out of the old one. I bought the car in May and the old one worked on test drive. No clicking but stopped working so I put in this aftermarket Murray from O'Rielys with lifetime warranty. Getting free replacement but it is not easy to change.
Do you recommend swapping gears from OE to aftermarket and/or lubing the crap out of gears?
Thanks, Big Dubbs. (Daryl)
Jul 10, 2025 at 10:52 AM
STEVE W.
  • 15,113 POSTS
If they are like other companies, they have different sizes in them.
Jul 10, 2025 at 11:18 AM
BIG DUBBS
  • 4 POSTS
Thanks!
Jul 10, 2025 at 12:24 PM
STEVE W.
  • 15,113 POSTS
You're welcome.
Jul 11, 2025 at 1:03 AM
