HVAC no air from middle vents?
2005 LINCOLN TOWN CAR
190,000 MILES • V8 • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I did this repair years ago on a Crown Vic or something similar maybe just can't remember what it was. No air from middle vents, or rear air. Only defrost and bottom/leg air. No matter what I chose only the defrost and bottom. I ran the test, and it gave me
12....42
12....63....
12...64
Not sure what these mean.
Jan 19, 2024 at 10:32 AM
Yep, this happens when the mode actuator goes out. Here is the location and how to change it out to fix the problem. Check out the images (below). Let us know if you need anything else.
Jan 19, 2024 at 12:17 PM
BHAMDOC1973
  • 2,008 POSTS
Would you remove the dash for this?
Jan 19, 2024 at 12:18 PM
BHAMDOC1973
  • 2,008 POSTS
Can you tell me where this is located? i removed the radio and trim but before i go further need more info please.
Jan 20, 2024 at 1:31 PM
It looks like it is behind the glove box.
Jan 21, 2024 at 9:44 AM
BHAMDOC1973
  • 2,008 POSTS
The one for mode change? I thought the one on that side us for passenger, some people changed those for when they lost air only on passenger side.
Jan 21, 2024 at 10:48 AM
BHAMDOC1973
  • 2,008 POSTS
I took glove box down and to the left there is one, removed and moved the door by hand nothing change as far as flow, removed cluster and panels under steering and there is another to the right, same thing, moved it and it did nothing.
Jan 21, 2024 at 2:40 PM
BHAMDOC1973
  • 2,008 POSTS
Can you get me the part numbers for the 2 actuators that set behind the dash on the vac blend door assembly?
Jan 22, 2024 at 8:06 AM
Yep, the mode actuator is near the glove box, check this diagrams out. Check out the images (below). Let us know how it goes. Sorry I dont have part numbers.
Jan 22, 2024 at 10:27 AM
BHAMDOC1973
  • 2,008 POSTS
This picture looks backwards for some reason. So, the temperature blend ones are on sides, which i can access by hand, i tried turning them and it didn't make a difference now i know they are temp blend ones. Another for recirculation is by blower. The last 2 are hidden. So am guessing the one u marked is one of them and the other is for the foot. Are these numbers corresponding to part number? Based on the codes i got, 2 of them which do you think are bad?
Jan 22, 2024 at 10:34 AM
the mode actuator sounds bad to me. That is the one I marked in the diagram above.
Jan 23, 2024 at 10:02 AM
BHAMDOC1973
  • 2,008 POSTS
I ordered the replacements for the ones behind the dash. On the other hand, when i try to put back the ones on the side for temp blend doors neither one ligns up. I removed them to check them, which are accessible from under the dash, it only goes in one way and even if i move the doors up the holes still wont lign up. Is there a trick to this?
Jan 24, 2024 at 6:34 AM
Not really, can you move the door pivot on the HVAC system so the actuator can be installed?
Jan 24, 2024 at 10:26 AM
BHAMDOC1973
  • 2,008 POSTS
Yes, but no matter what neither one aligns. Nothing blocking the doors and i can freely move then.
Jan 24, 2024 at 10:52 AM
BHAMDOC1973
  • 2,008 POSTS
Is there a way to test the old actuator on the bench?
Jan 26, 2024 at 6:03 AM
You can check for power and ground to the controller, here is a guide and wiring diagram for the system. Also, you may have the incorrect replacement part for the mode actuator. I don't have a way to test the actuator.
Jan 26, 2024 at 11:21 AM
anything?
May 10, 2024 at 11:44 AM
