then it should be scanned for codes by a mechanic to see if the control actually is the problem. try jumping the low pressure switch to see if a/c kicks on and see if lt/green wire in pic is sending power to switch finally see if power goes through the high pressure cut out switch. this is assuming Freon is in system and full. check all fuses in pic as well.
Jun 27, 2017 at 9:39 AM
