I can no longer adjust the temperature in my car (LTZ model) no matter if I am in or out of the auto mode. It seems I can only get air to flow through the defroster using full defrost the rest of the time air goes through the AC vents.
In auto mode if I turn the temperature either way to the far right or left the fan goes full speed blowing out cold air.
The fan switch works on in either mode.
I am wondering if replacing the entire control unit is what I need to do or if the problem could be something else?
https://www.gmpartscenter.net/oem-parts/gm-control-asm-htr-and-a-c-w-d-seat-and-p-23111247?origin=pla&gclid=Cj0KCQjw2f7bBRDVARIsAAwYBBtMMxDOxWTJtQUL6sdll8CJMlcpdrNDF4dICT2Pa1wqRs1yBE0HC0waAhbCEALw_wcB
I hate to spend the money on the unit if it will not fix the problem.
Thank you.
Thank you.
Aug 24, 2018 at 8:04 AM
