That sounds more like one of the temperature sensors are faulty. This car should have a built in diagnostic system to help you.
Open the hood and on the right side next to the washer fluid fill there should be two blocks with covers, pop the covers and you should find terminals. (images 1-3) That is a built in code reader. They were on the the 94/5 850.
Take the cable attached to Diag A and put it into the #1 port on the B unit (image 4)
Turn the key on. The red LED should start to flash.
Now for the testing. There are three different modes you can test in. All modes flash the LED to indicate the codes with a pause between digits.
So a Flash - Pause - Flash Flash - Pause - Flash Would be a 1-2-1 code. There are 43 possible codes the system can store and it will show if something is at fault in the ECC or HVAC system.
Mode 1 will read out the codes stored in the ECC unit. To enter mode 1 you press the button on the A unit for about 1 second and the LED will flash the three digit codes. If you get a 1-1-1 code it means the ECC has not stored a code.
Enter that mode and look in the chart for the code(s) you find. Also post them here and there are tests/repairs listed for each code. (image 5)
Mode 2 allows you to test the solar sensor (determines temperature and solar load on the system) and the speedometer link (if the car is moving it adjusts the heat/AC differently than setting still) To enter mode 2 you press the button twice for one second each press. The LED should start flashing faster. It should only flash 2 codes. 1-1-2 showing the Solar sensor is good and 1-1-3 Speedometer signal is OK
Mode 4 is a testing mode. You enter it by pushing the button four times, each press about one second long. It can be used to cycle the AC relay or to reset the servo positions after an actuator replacement. As you seem to have an AC control issue you could go into mode 4 and enter 1-1-1 within four seconds let the LED come back on after each press, that should cycle the AC relay five times ten seconds on and ten seconds off and indicate AC on the ECC panel as well.
Jun 29, 2018 at 2:57 PM
