Where is the HVAC/Aircond fuse located?
2007 CHEVROLET UPLANDER
34,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
BBER468
  • 10 POSTS
I was reading the hard reset instructions for the actuator and HVAC system. I cannot locate a fuse named either one (HVAC or Aircon). The closest fuse I could find is located under the hood and marked A/C compressor. Is that the correct fuse? Also, when you do the heat part do you have to turn off the A/C max?
Thanks
May 9, 2025 at 1:22 PM
Yep, the A/C compressor fuse will not work, you need to remove the HVAC/RPA/CRUISE fuse #17 and the CLUSTER/HVAC fuse #8. The first fuse is in the fuse panel under the hood and the second fuse is in the fuse panel inside the vehicle.
Here is the guide mentioned for clarity:
https://www.2carpros.com/articles/step-by-step-guide-to-reset-your-cars-hvac-system-an-essential-for-every
May 10, 2025 at 12:28 PM
