There was a pretty bad clicking noise coming from my dash and the A/C would go on and off with the noise. So, i searched a bit and found some answers. I opened up my center console and tested the defrost actuator and the vent actuator. They were both fine not shaved or anything, but i realized the white plastic rod the defrost actuator connects to is sticky i have to use a bit of force to move it. So, i tested it again with the actuator connected and realized the noise was because the actuator isn't strong enough to turn the rod. I've read that a broken mode door can cause this but before i tear my dash apart i wanted another opinion. What do you think?
Sep 15, 2022 at 11:55 AM
