I bought this vehicle listed above, which has an auto HVAC control. The controls work fine, that is the heat up and down, A/C, fan speed, all of that. The problem is that the display is either so dim I can't see it, or it is blank.
The truck has one more issue that may be related. That is, the backlight on the I/C cluster does not work until the headlamps are on. Any engagement of the headlamps (even fog lamps) and the all the cluster back lights illuminate.
Dec 11, 2022 at 6:41 PM
