I have a JGC Overland, it has dual climate zones. I'm always getting air blowing on defrost, it will switch to other vents but doesn't blow hard. I'm assuming that's because some of the air is still going to defrost. I hooked up my scanner and it gave me b11c5-11 for the code. Says mode door 2 (defrost) driver circuit shorted to ground. I don't know what part needs to be changed or where this is even located to check it. Is this different than the blend doors? I believe i have two of them, one on each side of the center area. Any help would be great!
Mar 3, 2023 at 9:05 PM
