If you notice a change in sound/pitch, it very possibly could be a wheel hub bearing. When they start to go bad, they can make a humming sound. When you turn, the vehicle's weight is distributed differently. For example, if you turn right, more weight is pushed to the left side of the vehicle and taken off the right side.
So, if it was to get quieter when turning right, that would indicate the right bearing is the likely cause simply because there is less weight on it under those conditions. Does that make sense? LOL
Let me know if you notice a change when turning now that you are more aware. Also, a recording may help. Finally, let me know how the pitch changes (louder or quieter) when turning in a specific direction.
Take care and I'll watch for your reply.
Jul 8, 2021 at 7:59 PM
